You begin the CA Process Automation installation by installing the third-party software. When this installation completes, the Orchestrator installation begins automatically.
Note: In Red Hat Enterprise Linux, to execute permissions on the .sh file, enable the execute permissions on the .sh files. For example, execute permission on the .sh files using the following commands:
chmod a+x Domain_Installer_unix.sh chmod a+x Third_Party_Installer_unix.sh
These files invoke the third-party installer and then the Domain Orchestrator installer.
The option sets the default language. Regardless of the language that is selected, CA Process Automation is installed with support for all available localizations.
The Welcome to the CA Process Automation third-party Installer Setup Wizard appears.
If the destination folder does not exist, the installer creates the folder. A minimum of 8GB disk space is required.
Important! Ensure that the CA Process Automation folder structure including installation location does not exceed 255 characters. CA Technologies recommend keeping the installation path (install_dir) to 64 characters or less.
The list of third-party prerequisites appears. Third-party pre-requisites for the Domain Orchestrator include JBoss Installation, Hibernate Installation, and JDBC Jar Installation. In CA Process Automation r 4.2, the ActiveMQ messaging service is used with JBoss 5.1.
The JDBC Jars Installation appears.
...your_dir\mysql-connector-java-5.1.19-bin.jar
...\DVD1\drivers\jtds-1.3.jar
(Optionally, you can browse to a different JDBC jar file.)
...DVD1\drivers\ojdbc14.jar
Note: You must specify at least one JDBC driver. Specifying multiple JDBC drivers for internal communication is typically not necessary. During the Domain Orchestrator installation, you can install additional JDBC drivers for use by other Orchestrators or agents with the Database operators (formerly the JDBC Module).
The Third Party Installer passes control to the CA Process Automation Domain Orchestrator installer. There may be a short interval where the UI for the Third Party Installer will have closed and the UI for the CA Process Automation Domain install has not yet appeared. This is normal.
