CA Process Automation provides the option to install the Domain Orchestrator silently, or unattended, by using a response file. The response file contains various predefined parameters for use during the installation process. Once you create a response file, you can edit and run the install script file to begin the installation.
An example response file has been provided in the root folder of DVD1. We recommend that you use a copy of this file as the base for your response file.
