After the Third-Party Installer installs third-party components, the Third-Party installation wizard starts the Domain Orchestrator installation wizard.
This section describes how to install a nonclustered Domain Orchestrator or the first node of a clustered Domain Orchestrator.
C:\Program Files\Java\jdk1.7.0_21
The JDK is validated.
Specifies whether the relevant components communicate over HTTPS (secure) or HTTP (basic).
Indicates that the entire communication channel is secure (uses HTTPS to communicate).
Indicates that the entire communication channel uses HTTP to communicate.
Select this check box to configure CA SiteMinder SPS with the Domain Orchestrator.
Defines a FQDN hostname of CA SiteMinder SPS.
Defines the port number of CA SiteMinder SPS.
Type of Server
Specifies the type of installation as New Orchestrator.
Specifies whether to install the Domain Orchestrator with the potential for clustering.
Install the Domain Orchestrator with the potential for clustering. Before you select this option, verify that you have completed the NGINX Load Balancer prerequisites or the F5 Load Balancer Prerequisites.
Install the Domain Orchestrator with no potential for clustering.
Defines the name of the Load Balancer Worker Node. Because the first installation of the Domain Orchestrator is the first node in the cluster, this value is typically node1.
If Apache is your load balancer, your entry must match the node name in the "worker.nodename.host" variable that is associated with this host in the Apache file apache_install_dir\conf\workers.properties. In the following example, the variable value, node1, is the value to assign here.
worker.node1.host=DomainOrchestratorHostName
If the workers.properties file specified worker.abc.host, then you would enter abc.
If F5 is your load balancer, accept the default. (The value of the worker nodes is not relevant to F5, so there is no tie-back to the F5 prerequisites that you performed.)
Default: node1 (Special characters, including dashes, are not supported.)
Specifies the public host name for the Apache server, NGINX server, or the F5 server. For example:
loadbalancerhost.mycompany.com
Defines the HTTP port for the Load Balancer.
If you change this value during the Apache, F5, or NGINX Load Balancer installation and configuration, update this value accordingly. This port is used with the Public Host Name value to browse to CA Process Automation. For example:
http://public-host-name:80/itpam
Default: 80
Defines the HTTPS port for the Load Balancer.
https://public-host-name:443/itpam
Default: 443
CA Process Automation displays your entry as the This Product is Licensed To value when you click Help, About.
Defines the password that controls access to the keys that encrypt passwords and other critical data. Use this same password when you install any other Orchestrator or when you add cluster nodes to an Orchestrator. The certificate password is specific to a single CA Process Automation Domain.
Matches your entry in this field with your entry in the Certificate Password field to verify the password.
Important! In the Set Certificate Password page, before you click Next, record your Certificate Password entry in a secure location for later reference. This same certificate password is required when you install standalone Orchestrators or when you add cluster nodes.
Defines the name of the CA Process Automation Start menu folder if you cleared the Do Not Create a Start Menu Folder check box. Accept the default or type the name of the Start menu folder for CA Process Automation.
Default: CA Process Automation 4.0
Specifies whether the specified short menu folder name is displayed for all users who log in to the server with the CA Process Automation Domain Orchestrator.
Selected: Display shortcuts.
Cleared: Do not display shortcuts.
Specifies whether to create an entry for CA Process Automation in the Start menu.
Selected: Create a Start menu entry for CA Process Automation.
Cleared: Do not create a Start menu entry for CA Process Automation.
Defines one of the following properties:
Defines the Domain Orchestrator name that appears in the CA Process Automation Configuration browser.
Specifies whether communication to CA Process Automation is secure, as opposed to the standard basic communication. This value controls whether the HTTP port or the HTTPS port is enabled.
Selected: Use the HTTPS protocol for communication.
Cleared: Do not use the HTTPS protocol for communication. Use HTTP instead.
Defines the port that the Domain Orchestrator uses to communicate with other Orchestrators and agents.
Default: 80 (basic: HTTP), or 443 (secured: HTTPS)
Defines the HTTP port that is used for the web server if the Support Secure Communication check box is cleared.
Note: This port is part of the URL that is used to access CA Process Automation web services and the CA Process Automation login screen.
Default: 8080
When you select Support Secure Communication, this field specifies the port used in the URL that accesses CA Process Automation Web services and the browser-based CA Process Automation UI.
Default: 8443
Note: Select “Support Secure Communication” to enable input to this field.
Defines the Java naming server port that the web server uses.
Note: This port must not be accessed from outside of this host system.
Default: 1099
Defines the RMI port that the web server uses.
Default: 1098
Defines the SNMP trap listener port for CA Process Automation.
Default: 162
This directory must be writable by all users.
Specifies whether to enable the use of PowerShell.
Selected: Enable the use of PowerShell, setting the PowerShell execution policy at the specified path to Remote Signed.
Cleared: Do not enable the use of PowerShell.
CA Process Automation auto-detects the PowerShell path.
Note: When you click Next, the installation program validates the provided PowerShell path.
Defines the FQDN of the CA EEM server that CA Process Automation uses to authenticate and authorize CA Process Automation users. If you are configuring EEM for High Availability (HA), you can also define a backup CA EEM server. Use a comma as the delimiter between the server names.
EEM Application Name
Defines how the CA Process Automation application name appears in CA EEM. If you use the same CA EEM server with multiple CA Process Automation Domains, each CA Process Automation domain must have a unique EEM application name. The name that you enter here appears in the drop-down list of the CA EEM server login page.
If you are upgrading, this field is already populated with the value used in the initial installation. This value preserves the CA EEM user group assignments, custom policies, and custom groups. CA EEM uses this value to identify this CA Process Automation domain.
Default: Process Automation
Use FIPS-Compliant Certificate
Specifies whether to use FIPS-compliant certificates. This setting must match the CA EEM setting for FIPS Mode.
Note: To determine the CA EEM setting for FIPS, click About in CA EEM; the Product Specifications include FIPS Disabled or FIPS Enabled.
Selected: FIPS Mode is set to ON in CA EEM.
Cleared: FIPS Mode is set to OFF in CA EEM.
Specifies whether to register the "EEM Application Name" value for CA Process Automation with CA EEM and generate the certificate that CA Process Automation uses to connect to its application in the CA EEM server. The CA EEM SDK handles the connection. If prompted, indicate that you want to upgrade the CA Process Automation application in CA EEM.
Selected: Enables the Register button. (See Step 16.) Disables the EEM Certificate File field. For a new installation of a Domain Orchestrator, always select this check box. When you complete the EEM Security Settings fields, click Register.
Cleared: Disables the Register button. Enables the EEM Certificate File field.
install_dir/server/c2o/.c2orepository/public/certification
Note: If you are upgrading, this field is automatically populated with the path to your certificate file.
Defines the CA EEM certificate file to use for CA Process Automation. You can typically accept the default value.
Defaults:
PAM.cer if you selected the Use FIPS-Compliant Certificate check box.
PAM.p12 if you cleared the Use FIPS-Compliant Certificate check box.
If required (see Notes), click Browse and find the location of the certificate key, for example, the PAM.key file. Once the certificate file uploads, the installer places it in this directory:
Notes:
Required if you are not using FIPS. Defines the CA EEM Certificate password. This password protects the PAM.p12 certificate; CA Process Automation needs this password to open and use the PAM.p12 certificate.
(Applicable only if you plan to reference multiple Active Directory domains when you configure CA EEM Release 12.51. See Step 17.) Specifies the AD domain to use as the default domain. CA Process Automation users belonging to the domain specified here can log in to CA Process Automation with their unqualified user name. Users belonging to other AD domains must specify their principal name (domain\username or username@domain) and password when they log in to CA Process Automation. This entry must match the Domain field entry for one of the multiple AD domains you configure for the CA EEM referenced user store.
CA EEM must be suitably configured to authenticate with the username@domain form of the principal name.
Note: See Configure CA EEM to Permit Referenced Users to Log in with Their Email Name.
Specifies whether CA EEM uses the NTLM protocol to authenticate CA Process Automation users.
Selected: Enables NTLM pass-through authentication. CA EEM uses the NTLM protocol to authenticate users who browse to CA Process Automation.
Cleared: Disables NTLM pass-through authentication. Users who browse to CA Process Automation must enter credentials in the CA Process Automation login dialog. CA EEM validates the credentials with the referenced Microsoft Active Directories to authenticates users.
EEM Admin Username
Defines the CA EEM administrator user name. Type EiamAdmin.
EEM Admin Password
Defines the password for the EiamAdmin user account. If you installed CA EEM, enter the password that you created for the EiamAdmin user. Otherwise, contact the CA EEM administrator to get the password.
install_dir/server/c2o/.c2orepository/public/certification/PAM.p12
Note: The certificates are not regenerated if you are prompted to upgrade the CA Process Automation application in CA Embedded Entitlements Manager, and you choose not to upgrade it.
The following bulleted list describes the use cases:
https://hostname:5250/spin/eiam
The CA Embedded Entitlements Manager dialog opens.
Your name appears under Users in the Users pane.
Your user account has two User Details sections. The top section lets you define a group for your role in CA Process Automation. The bottom section, "Global User Details" contains information from the external directory.
The Available User Groups list contains a group for each default role.
The Verify EEM Settings screen displays the following fields:
Indicates whether a connection can be established to the specified CA EEM server with the values provided in the CA EEM settings screen.
Limits: OK, NOT OK
Note: If the value evaluates to NOT OK, the following fields are not displayed.
Indicates whether the user can be authenticated, that is, whether login is permitted.
Limits: OK, NOT OK
Indicates whether the user has authorization to perform administrator tasks. Members of the PAMAdmins group have this authorization.
Limits: Yes, No
Indicates whether the CA Process Automation application schema in the EEM server is upgraded. If the message "Upgrade not required" appears; click OK.
Note: This field is displayed only when the value is NOT OK. When the value is NOT OK, upgrade the instance.
Specifies the Database system type. Select a supported type from the drop-down list.
Values: MySQL, MS SQL, Oracle
Note: If this installation is for production use, best practice is to select either MS SQL or Oracle. MySQL is an appropriate choice for a lightly-loaded Domain Orchestrator.
For MS SQL and MySQL, defines a user name that is authorized to create and access the database on the database server. The account must have permissions to create the database on the server or ownership (DBO) for an existing database. The following values are auto-populated based on the database selection:
For Oracle, defines an existing schema that is authorized to create and access the CA Process Automation database objects.
Defines the password that is associated with the specified User Name.
Defines the host name or IP address of the database server.
Defines the connection port that is configured on the target database instance.
Defines the name of the database in which to store Library objects and other data.
Each Orchestrator can have its own repository, or library, data store. You can also share the library data store across Orchestrators. Each data store must have a unique name. Consider establishing a naming convention for your CA Process Automation data stores with this initial installation.
Consider establishing a naming convention for the databases that contain your CA Process Automation data stores with this initial installation.
Consider housing each data store in its own database for improved performance.
Note: If you have an Oracle RAC Database or otherwise need to refer to a Service Name, you can configure that as a post-installation task. See Change the Database Configuration to Use an Oracle Service Name.
Defines the JDBC driver JAR file for the specified database type. The drivers folder in the DVD1 folder of the installation media provides default drivers for Microsoft SQL Server and Oracle database servers.
SQL Server: jtds-1.3.jar
Oracle: ojdbc14.jar
MySQL: Click Browse, then navigate to the JAR file you downloaded (for example, mysql-connector-java-5.1.18-bin.jar).
Defines the rules for sorting data for MS SQL and Oracle. Case-sensitivity, accent marks, kana character types, and character width can be part of the rule set. This field is a drop-down list. It is best practice to accept the default value. This field is not applicable to MySQL.
Default: SQL_Latin1_General_CP1_CI_AS
Select this check box to provide connection string to connect to the Oracle database.
Note: This check box is enabled for Oracle database only.
Enter a jdbc connection string in one of the following formats:
jdbc:oracle:thin:DatabaseServer:PortNumber:DatabaseName
jdbc:oracle:thin:@(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=hostname)(PORT=portnumber)) (CONNECT_DATA=(SERVICE_NAME=serviceid)))
If a message indicates that databases are missing, close the message and click Create Database. Except for Oracle, databases that the Orchestrator requires can be created during installation.
Create the Repository (Library) data store if you specified MS SQL or MySQL.
Note: When using an Oracle database, you already created the Repository (Library) schema as part of the Oracle database prerequisites.
A message indicates that a database has been created with the name you provided. Click OK. Click Test Database again.
The Runtime Database fields are similar to the Database Setting fields for the Repository (Library) Database except for two fields. See Step 20 for descriptions of other fields.
Specifies whether to copy the Repository database (also known as Library data store) settings to the Runtime Database settings screen.
Selected: Copies the Repository database (Library data store) settings to this dialog. This option can save you time if you are using the same database for both CA Process Automation data stores. If you select this option, type the Runtime data store name in the Runtime Database field. Then click Test Database Settings to test connectivity from the Domain Orchestrator to the database server port for the specified database instance. Then click Create Database to invoke the creation of the database for the Runtime data store.
Cleared: Does not copy the Repository (Library) database settings to this dialog. This option is appropriate if you are using a different type of database for run-time data than you are using for library records.
For MS SQL and MySQL, defines the name of the database in which CA Process Automation run-time instances are stored. No two Orchestrators can point to the same Runtime data store. We recommend that this database be different from the one used by the other data stores.
For Oracle, defines the Instance Name or SID of the database in which CA Process Automation run-time instances are stored. No two Orchestrators can point to the same Runtime data store. We recommend that you use a different schema in this instance than the one used by the other data stores.
You cannot share a Runtime data store across Orchestrators. (However, all nodes of an Orchestrator cluster share the same Runtime data store.)
For MS SQL or MySQL, enter a user name that is authorized to create and access the database on the database server. (For example, type sa for MS SQL; type root for MySQL.)
For Oracle, enter a schema that is different from the one used by the Repository data store and which is authorized to create and access the reporting-related database objects.
For MS SQL and MySQL, type a unique name for the reporting database.
For Oracle, retain the value unless you want to change the database instance.
See the following field descriptions:
Specifies whether to copy Repository (Library) data store settings to the Reporting Database settings screen. The Reporting Database fields are similar to the Database Setting fields for the Repository (Library) Database except for two fields. See Step 20 for descriptions of other fields.
Selected: Copies the Repository Database settings to this dialog. This option can save you time if you are using the same database for both CA Process Automation data stores.
Cleared: Does not copy the Repository Database settings to this dialog. This option is appropriate if you are using a separate database for the reporting data store. We recommend that you dedicate a database for the reporting data store.
Defines the name of the database that houses the reporting data store.
By default, the JDBC drivers that are uploaded in the Third-Party Software installation are displayed and are not selected. You can use the Add Files button to add more JAR files.
Select each JAR file that you want deployed. Verify that you selected all of the drivers that you want to deploy for JDBC Operator usage on CA Process Automation agents and Orchestrators. Use the Add Files button to add more drivers.
It is not necessary to anticipate the needs of designers for JDBC drivers. A domain administrator can deploy JDBC drivers as they are needed.
Note: For more information about adding and managing Orchestrator and agent resources, including JDBC JAR files, see the Content Administrator Guide.
When you are satisfied with your selection of JAR files, click Next.
Installation of the Domain Orchestrator is complete.
The initial startup of CA Process Automation after an upgrade or installation can take extra time while the product adjusts the database schema. A rough guide is one hour per GB of data; however, this will vary depending on DBMS vendor, machine specs, and volume of data. Start the Orchestrator. Verify the correct operation of this initial Orchestrator before proceeding with installing other system components.
