You are prompted to generate the RLDD after editing the repository entries, from either Configure_Web_Services, or Change_Repository_Settings. You can also directly generate the RLDD by launching Create_RLDD.
Notes:
The Create Report List Data Dictionary Entries section appears.
This option uses a single password for each repository.
Note: This option is useful if all your repositories use external security or you synchronize user names and passwords in some way other than external security.
This option lets you specify a different password for each repository. A repository name is displayed and you are prompted to enter a user name and password. Repeat the step for each repository.
This option allows you to continue to the next section without Generating the Report List Data Dictionary.
After entering all the Repository user names and passwords, a failure or success message is displayed.
If all updates, were successful the program automatically continues to the next section: Save Configuration Changes.
Otherwise, the Create Report List Data Dictionary Failure Options menu appears and you can then continue to Step 5.
This option lets you go to the previous menu, the Create Report List Data Dictionary Entries Menu, so that you can reenter user names and passwords.
This option lets you return to the Repository Settings menu. You can change or remove repository entries that cause the creation of the Report List Data Dictionary failure.
Note: This option is only available from Configure_Web_Services or Change_Repository_Settings.
Important If the RLDD generation fails you cannot access CA OM Web Services or access certain repositories that are defined to it.
