Post-Installation and Configuration Tasks › Configure CA OM Web Services › Configuration Tool First Steps
The CA OM Web Services Configuration Tool, in interactive mode, includes the following four sections:
- CCI Settings
- License
- Repository Inclusion and Setup
- Create Report List Data Dictionary.
Note: To configure and run all four sections, run "Configure_Web_Services".
- Launch the Configure_Web_Services application to run all the sections of the interactive configuration tool.
- Enter the location of the WAR, or EAR file.
- Select backup folder location.
Note: If your selected backup folder location does not exist, you are prompted to create a configuration backup folder.
- Load configuration settings from either the webapp or backup location.
Note: The loaded settings are the default settings that are listed in the configuration tool.
More information:
Running the Configuration Tool (Interactive Mode)
Configuration Tracing
