Previous Topic: Configure CA OM Web ServicesNext Topic: Launch Configuration Tool HP/UX
Running the Configuration Tool (Interactive Mode)
You can change the initial configuration settings with the configuration tool available in CA OM Web Services.
After the product installation the configuration tool is located in the <product install>/utilities directory. This tool is used to modify settings in the following sections: CCI, License Server, and CA OM Web Services repositories. The configuration tool also lets you to generate the report list data dictionary.
You can execute "Configure_Web_Services" to use all functions or execute "Change_CCI_Settings", "Change_License_Server", "Change_Repository_Settings", or "Create_RLDD" to modify each individual section.
Note:
After the configuration tool is launched, it prompts you for the target CA OM Web Services package. Press Enter to use the default package or specify a CA OM Web Services package at a different location. The default package is the one installed from your initial installation.
Note: Since the package for updating is an EAR or a WAR file, you redeploy the archive after the update. The tracing information is available in the logs subfolder of the utilities folder.
More information:
Configure CAICCI
Configure the License Server
Create or Manage Repository Definitions
Configuration Tracing
