Previous Topic: Dragging and Dropping FilesNext Topic: Chat Feature
Set the Maximum Bandwidth
You can set the maximum bandwidth used in transferring files, making remote control connections, or recording sessions.
To set the maximum bandwidth rate
  1. Right-click a computer name in the Global or Local Address Book pane and click Open.
    The Connection Settings dialog appears.
  2. Click the Advanced tab.
  3. Select the maximum amount of bandwidth from the Bandwidth Limiter drop-down list of options.
    Note: Unlimited is the default maximum.
  4. Click OK.
    The maximum bandwidth is set.
More information:
Connection Settings Dialog
