Previous Topic: Transferring FilesNext Topic: Set the Maximum Bandwidth
Dragging and Dropping Files
Drag-and-drop is a feature that lets you transfer files from one computer to another. For example, it lets you move objects from a directory on one computer to a directory on another computer.
You drag-and-drop by clicking the file, holding and dragging it to the destination folder, and dropping it there.
