Use the Viewer tab to set the viewer’s remote control session behavior at the start of the connection. The options set here can be modified during the session using the toolbar or the Active Sessions context menu options.
Note: Changes made on this tab only apply during the current session and are lost if the session is removed.
To set remote control session options
Lets you view a session in full screen mode if set to True.
Default: False
Note: This field is not available when using the RC Viewer Web Interface.
Once connected, lets you view a session in an undocked viewer window if set to True.
Default: False
Lets the host image display in the viewer window without modification.
Default: True
Lets the viewer computer, with a smaller resolution than the host computer, display the active area as the mouse moves around the screen.
Default: False
Scales the host image to fit the viewer window.
Default: False
Shrinks the host image to fit the viewer window.
Default: False
Click Browse to invoke the File Save dialog, letting you specify a recording file name.
Default: A default name is automatically generated, based on the default recording path, computer name, and current date and time.
Remote Control attempts to connect you to the host computer after all fields in the dialog are completed.
Note: The Help button is not available when using the RC Viewer Web Interface.
