Previous Topic: Specify Connection SettingsNext Topic: Set Viewer Session Options
Control Connection Speed and Set Visual Effects
Use the Experience tab to control the connection speed and set visual effects.
To control connection speed and set visual effects
  1. From the Connection Speed drop-down list, select how the host should adjust various "user experience" features to decrease network traffic and improve performance. This setting does not actually set your host computer's connection speed. Valid values are as follows:
    Default: Fast LAN (100 Mbit)
    Note: If you manually change any of the other options in the Experience tab, the Connection Speed option changes to Custom.
  2. In the Appearance group box, select one or more of the following options:
    Disable desktop wallpaper
    Disables the host's wallpaper during a connection. Disabling the wallpaper improves the performance by increasing the speed of the remote control session when the host is using background wallpaper. For example, the background wallpaper is typically a large bitmap (approximately 3MB), which can take time to transmit over a slow network such as a phone line. Switching this off improves the initial startup time.
    Note: This option has no effect when connecting to Linux or Mac OS X hosts.
    Default: True
    Disable contents of windows while dragging
    Increases performance, if True, by asking Windows not to display the whole content of a window when it is dragged from one part of the screen to another. Instead, a wire frame is displayed, which decreases the amount of video data being transmitted.
    Default: False
    Disable window and menu animation
    Disables window and menu animation during a connection. Disabling animation improves performance by increasing the speed of the remote control session when the host is displaying menus and minimizing and maximizing windows.
    Default: False
    Disable visual styles and effects
    Tells the host to set Windows to disable Windows XP-style visual effects. Disabling these results in the use of the Windows classic style taskbar, common controls, and buttons during a remote control session. Performance increases because the amount of video data being sent to the viewer is decreased.
    Default: False
    Embed missing fonts
    Embeds missing fonts in the viewer computer. The Embed Missing Fonts option affects the behavior of the viewer when it is viewing a host computer with fonts that the viewer does not have.
    When this option is enabled, and the host computer draws some text with a font that the viewer does not have installed, the host automatically sends the font file to the viewer and temporarily installs it there. This enables the viewer to give an accurate reproduction of the host computer’s screen. When the option is disabled, and the host computer draws some text with a font that the viewer does not have installed, the viewer chooses the closest matching font. This closest match does not give a perfect reproduction of the original font and may appear to be a slightly different size.
    Font files can be large, especially for East Asian languages, so sending the font files during a Remote Control session over a low-bandwidth connection can result in a significant pause while the font file is transmitted. Therefore, the Embed Missing Fonts option is automatically turned off for low-bandwidth connections.
    Note: The licensing terms of some commercial fonts do not permit embedding. Remote Control automatically uses font matching for these fonts.
    Default: True
  3. From the Color Reduction drop-down list, select an option that tells the host how to reduce the color depth of bitmaps before transmission, thereby decreasing the amount of data that must be transmitted to the viewer and improving performance. Reduction occurs only if the color depth of the host's display is greater than the setting.
    Note: This option affects only the color of images transmitted. In gray scale mode, most of the host view is still represented in color.
    No Color Reduction
    Displays bitmaps at their native color depth. No reduction takes place.
    High Color: 16 bits/pixel
    Reduces bitmaps to limited range, true-color images. Most images appear indistinguishable from their originals, but some color gradients may appear banded. Dithering can be enabled to mitigate this effect.
    TV Color: 12 bits/pixel
    Reduces the bandwidth in a way that is less noticeable to users, making it virtually imperceptible from the No Color Reduction option in most cases.
    Low Color: 8 bits/pixel
    Reduces bitmaps to a very limited color palette, which may cause color distortion in some bitmaps. The 8 bits/pixel color images are the same size as 8 bits/pixel gray scale images. Dithering can be enabled to mitigate this effect.
    Greyscale: 8 bits/pixel
    Reduces bitmaps to 256 shades of gray. This produces a “perfect” gray scale reproduction of the original color bitmap. However, areas of different color that have the same intensity may display as the same shade of gray.
    TV Color: 6 bits/pixel
    Reduces the bandwidth in a way that is less noticeable to users. This option uses less bandwidth than the TV Color: 12 bits/pixel option, but with some loss of detail.
    Greyscale: 4 bits/pixel
    Reduces bitmaps to 16 shades of gray, with some loss of detail. The 4 bits/pixel images are half the size of 8 bits/pixel images. Dithering can be enabled to mitigate this effect.
    Greyscale: 1 bit/pixel
    Reduces bitmaps to bi-level black and white only. Dithering is recommended for this setting.
    Default: No Color Reduction
    Note: In CA ITCM Release 12.5, you can also change the color depth during a session using the Color Reduction context menu option.
  4. (Optional) Select the Dither reduced colors option to specify how the colors are blended during the reduction process.
    This option is enabled for certain color depths. It compensates for the loss of color accuracy by alternating between the two colors nearest to the original color. This improves the rendition but reduces performance.
    Note: Dithering is only available in High Color: 16 bits/pixel, Low Color: 8 bits/pixel, Greyscale: 4 bits/pixel, and Greyscale: 1 bit/pixel reduction.
  5. Click OK.
    Your visual effects settings are saved.
Note: The Help button is not available when using the RC Viewer Web Interface.
