Use the Search dialog to find a computer in an address book.
This dialog contains the following fields:
Specifies the name of the computer that you want to find.
Specifies that child address books be searched as part of the search process.
Default: True
Specifies that folder names be matched as part of the search process.
Default: True
Displays all computers by name and parent that match the specified criteria.
This dialog contains the following buttons:
Starts the search process.
Takes you directly to the selected computer in the Search Results list view.
