Connection Tab
Use the Connection tab in the Properties dialog to view or modify the protocol and address of a computer. It also lets you reorder connection addresses.
This tab contains the following fields:
Displays a list of the configured protocol and address pairs that can be used for the connection.
Displays tips for selecting options or entering information in fields or dialogs.
This tab contains the following buttons:
Change the order of the computer addresses in the list of connections.
Invokes the Protocol/Address dialog, which lets you add a new address for connecting to the remote computer. You may enter more than one for each computer.
Invokes the Protocol/Address dialog, which lets you change the existing details of a connection address for a remote computer.
Removes the address entry from the list of connections.
