Previous Topic: Synchronize the Global Address BookNext Topic: Create a Local Address Book
Local Address Book
The local address book is your personal address book. It contains information about each computer in a customized collection of computers that you define. The local address book is available from the Viewer root node or the Viewer pane. You can define the user of the local address book using the Address Book Properties dialog.
Note: Port numbers are entered automatically in the global address book but manually in the local address book.
You manage computers by creating an address book hierarchy. You may add, delete, and search for computers using this feature. Right-clicking a computer in the Local Address Book pane displays the available menu options.
You can also import and export local address books. An address book consists of an XML file, which the Import/Export feature modifies appropriately so that this file can be used in its new location. An imported address book either merges its data into an existing local address book or replaces the local address book.
Note: The content of encrypted fields in an address book is protected, enabling the content of the address books to be shared among users without compromising security.
More Information:
Find a Computer
