Previous Topic: Multiple Address BooksNext Topic: Synchronize the Global Address Book
Global Address Book
The global address book (GAB) contains the address books created by the remote control manager. Users' computer information, along with their protocol information, is downloaded to the Global Address Book node in the Viewer pane. The global address book is downloaded from the remote control manager and is filtered to contain only the computers to which the user of the viewer has inherited access permissions from the parent address book group. Only the administrator of the remote control manager can edit the address books.
Note: Port numbers are entered automatically in the global address book but manually in the local address book. If a computer changes its primary network address, the host sends the change to the manager so it can update the GAB.
The global address book is available from the Viewer root node or the Viewer pane. You can define the user of the global address book using the Global Address Book Properties dialog.
More Information:
Find a Computer
