Previous Topic: Browse for FolderNext Topic: Configure TCP Options
Configure File Transfer Options
Use the File Transfer tab to set up options for transferring files. From this tab you can choose how to confirm when transfers take place, filter files by date, enable or disable encryption, enable or disable the ability to overwrite or delete Read Only files, and enable or disable the ability to preserve attributes of transferred files.
To configure File Transfer options
  1. Right-click the Viewer node and select Properties.
    The Viewer Properties dialog opens.
  2. Select the File Transfer tab.
  3. In the Confirmation of file transfers group box, select one of the following confirmation options:
    Confirmation off
    Transfers all files without any user confirmation if set to True. Existing files are overwritten with new files.
    Default: False
    Ask if a file is to be replaced
    Displays a standard confirmation dialog before overwriting any existing files.
    Default: True
    Ask if a file is to be created
    Displays a standard confirmation dialog before creating any files.
    Default: False
    Always ask
    Always displays a standard confirmation dialog before creating or overwriting any files.
    Default: False
  4. In the Filter transfers by date group box, select one of the following filtering options:
    Transfer all files (no filter)
    Transfers all files to the remote computer.
    Default: True
    Transfer if date of source is later than existing file in target folder
    Transfers only files with creation dates earlier than the destination if set to True. Select this option to transfer a file if the date of the source file is newer than the existing file in the target folder. If the source file is older than the destination file, or it does not exist at the destination, it is not transferred.
    Default: False
    Transfer if source does not exist in target folder
    Transfers only files that do not exist at the destination if set to True. If a file exists at the destination, it is not transferred even if the file is more recent.
    Default: False
    Transfer if date of source is later than existing file or source does not already exist
    Transfers source files with dates that are newer than the existing file in the target folder or only files that do not exist at the destination folder.
    Default: False
  5. In the Misc group box, select one or more of the following miscellaneous file transfer options:
    Encrypt file transfer data
    Encrypts files that are sent or received between the viewer and host session if set to True. This option only applies when the viewer's Encryption option is set to Off or Keyboard. When Encryption is set to Full, the result is the same as setting this option.
    Default: False
    Note: If the target host is operating in FIPS‑preferred or FIPS‑only mode, this option has no effect—the data is always encrypted using FIPS‑compliant cryptography.
    Overwrite or delete read only files
    Overwrites or deletes files, which are labeled with the Read Only attribute, on either the viewer or the host.
    Default: False
    Preserve file attributes after copy
    Preserves file attributes, such as Read Only and Hidden, when sending or receiving files between the viewer and host.
    Note: This option applies only to files and not directories. The attributes of existing directories will remain unchanged (but may gain the Archive attribute), and directories created by File Transfer will acquire default attributes.
    Default: True
    Show hidden files and folders
    Displays otherwise hidden files and folders with the relevant drive list information.
    Default: False
  6. Click OK.
    Your file transfer configuration options are saved.
