Previous Topic: Configure Script for Locations RuleNext Topic: (Optional) Configure Script Timeout
(Optional) Configure Scan Timeout
If you use the Subnet Scan, the Scan Timeout configuration determines the maximum interval that the scan waits for a scalability server to respond.
  1. Double-click Configure Scan Timeout, then click Setting Properties in the Tasks portlet.
    The Setting Properties dialog opens.
  2. Modify the Value field as appropriate for your environment, then click OK.
    Default: 30
    The Configure Scan Timeout parameter is configured.
