Common Policy Group (Common Agent)
The Common policy group contains the following policies. You can modify the policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Defines whether the agent uses location awareness system or not.
Default: <false>
Specifies the address of the scalability server to which this agent registers.
Default: <locally managed>
