Previous Topic: Configure Subnet Scan for Locations RuleNext Topic: (Optional) Configure Scan Timeout
Configure Script for Locations Rule
You can add a script to run on the agent and determine which scalability server to use. Your responsibility includes delivering the script to the agent computer.
  1. Double-click the new value in the Script column.
    The Setting Properties dialog opens.
  2. In the Value field, specify the name of the DM script, then click OK.
    Note: You can specify the script location as an absolute or relative path. A relative path is relative to the ITCM installation directory, which is typically at one of the following locations:
    Windows:
    C:\Program Files(x86)\CA\DSM
    Unix, Linux:
    /opt/CA/DSM
    The feature passes the following parameters to the server selection script:
    -o <output file name>
    Names the file where the script writes the name of the scalability server that it identifies.
    -x <error file name>
    Names the file where the script writes any error information it generates.
    -a <matching address>
    Identifies the address that matched, resulting in running this script.
    The DM script is configured for the location rule.
    Note: If you specify the script, leave the Scalability Server and Subnet Scan columns empty. If you are not using Subnet Scan, leave the Subnet Scan column empty.
Example:
rem ---------------------------------------------------------------------
rem Simple location aware server identification script
rem This script writes a hard coded server name to the output file
dim sMatchingAddress as string
dim sOutputFileName as string
dim sErrorFileName as string
dim X as Integer
FOR X=0 to argc()
	rem Read the output file from the provided parameters
	if ( argv(X)="-o") THEN
        sOutputFileName = argv(X+1)
        ENDIF
	rem read the matching address from the provided parameters
    if ( argv(X)="-a") THEN
        sMatchingAddress = argv(X+1)
        ENDIF
	if ( argv(X)="-x") THEN
        sErrorFileName = argv(X+1)
        ENDIF
NEXT X
dim fHandle as integer
fHandle = OpenFile(sOutputFileName,O_WRITE)
IF NOT(EOF(fHandle)) Then
	WriteFile(fHandle,"sampleserver.ca.com")
	CloseFile(fHandle)
	exit
ENDIF
exit
