Previous Topic: (Optional) Configure Scan TimeoutNext Topic: (Optional) Configure Scheduler for Refresh Location Awareness
(Optional) Configure Script Timeout
The Script Timeout configuration determines the maximum interval during which to run the script. The scripts stop running when the specified interval elapses.
  1. Select Script Timeout, then click Setting Properties in the Tasks portlet.
    The Setting Properties dialog opens.
  2. Modify the Value field as appropriate for your environment, then click OK.
    Values:
    Default: 300
    The Script Timeout parameter settings are configured.
