You can pass default parameters into the web page of the RC Web Viewer interface through the URL, using the following format:
file://C:/Program%20Files/CA/DSM/bin/RCViewer.html?variable=value&variable=value
The following is a list of variables you can include:
Specifies the type of connection. Valid values are as follows:
0 = View
1 = Stealth View
2 = Shared Control
3 = Classroom
4 = Exclusive Control
5 = Secure Control
6 = Meeting
Default: 2 (Shared Control)
Defines the user name or URI with which to connect.
Defines the password of the designated user.
Defines the address to which to connect.
Specifies the protocol to use for the connection.
Default: TCP
Indicates whether to connect immediately when the page loads. Valid values are Yes/No or True/False.
Example
file://C:/Program%20Files/CA/DSM/bin/RCViewer.html?Address=mytestcomputer&UserName=winnt://mytestcomputer/Administrator&Password=secret&Connect=yes
Note: The RCView.html web page is provided as an example of how to integrate the viewer into web pages and applications using the RC ActiveX control; it is not intended for use in a production environment. The URL processing is performed by a script inside the web page. In a production environment, CA recommends you use server-generated pages (for example, ASP) to populate the web page with default data.
