Previous Topic: RC Web Viewer InterfaceNext Topic: View Tab
Session Tab
Use the Session tab to launch remote control features and to disconnect the session.
This tab contains the following fields:
Disconnection Type
Specifies how to disconnect from a session currently in progress. Valid values are as follows:
Normal
Disconnects the current session.
Lock
Disconnects the current session and locks the host computer.
Logoff
Disconnects the current session and logs off the current user on the host.
Reboot
Disconnects the current session and restarts the host computer.
Default: Normal
This tab contains the following buttons:
Disconnect
Ends the current session according to the specified disconnection type.
Start Recording
Starts recording the current remote control session.
Connect Printer
Opens a local Print dialog if the host computer supports printer redirection.
Connect Smart Card
Connects a smart card reader and activates smart card redirection of user credentials from a Remote Control viewer to a remote host computer.
Note: If more than one smart card reader is installed, the Select a Smart Card Reader to Connect dialog appears.
Show Chat
Activates a chat session with the remote host user.
More information:
Chat Feature
Printer Redirection Feature
