Change Configuration Policy Setting to Centrally Managed
You can change an unmanaged (Locally Managed) policy setting to a centrally managed policy setting to have administrative control over configuration policy, as shown in the following example.
To change the common agent setting, Message expiration, from unmanaged to centrally managed
All the setting names, values, and descriptions are shown in the common configuration pane.
Alternatively, right-click and select Setting, Centrally Managed from the context menu.
The Message expiration setting status is set to Centrally Managed and its value is displayed.
