Previous Topic: Change Configuration Policy Setting to Centrally ManagedNext Topic: Seal a Policy
Reset a Value to Default
For user-defined policies only, you can remove the current value from a setting at any time and reset it to the default value.
To reset a value to the default value
  1. Unseal the policy and navigate through the tree view to select the specific setting.
  2. In the Tasks portlet, click Use Default Value.
    Alternatively, right-click the setting and select Use Default Value from the context menu.
    The value of the setting is reset to its original default value.
  3. Seal the policy.
Note: This applies only to user-defined policy values, not to the default policy.
