Previous Topic: Remove All ConfigurationsNext Topic: View the Properties of a Configuration Policy
Configuration Policy Node (Control Panel)
The Configuration Policy node and corresponding pane contain the DSM default computer policy and any user-defined policies. When you define a new configuration policy based on the default policy, a new configuration policy node is added to this section of the DSM Explorer tree. Its policy groups are displayed correspondingly in the right pane, which is titled with the specified configuration policy name. You can also copy an existing configuration policy and add it to the DSM Explorer tree.
