Change Configuration Policy Setting to Locally Managed
You can change a centrally managed policy setting to an unmanaged (Locally Managed) policy setting to enable users to control their own configuration policy, as shown in the following example.
To change the common agent setting, Message expiration, from centrally managed to unmanaged
All the setting names, values, and descriptions are shown in the common configuration pane.
Alternatively, right-click and select Setting, Locally Managed from the context menu.
The Message expiration setting status is set to Locally Managed.
