Previous Topic: Modify Settings (Tables)Next Topic: Change Configuration Policy Setting to Locally Managed
Configuration Policy Setting Status
The status of a configuration policy setting can be set to Centrally Managed (managed) or Locally Managed (unmanaged). The chosen setting allows administrative control over configuration policy.
managed policy icon Centrally Managed
Controls the behavior of plug-in components. Managers push a Centrally Managed setting onto a remote computer.
This setting is indicated by a table icon with a section reference mark.
unmanaged policy icon Locally Managed
Allows remote users to be able to control this setting. A Locally Managed setting is one that is configurable on the remote computer.
This setting is indicated by the crossed-out table icon with a section reference mark.
