The Operating System pane displays information about the operating system installed on the computer asset.
Note: The inventory information available in this pane depends on whether asset management is installed.
This pane contains the following columns:
Displays information about the operating system installation on the computer, such as the build number, service pack, and install date.
Displays the settings given in the windows display properties, such as the screen resolution, and adapter name.
Displays the regional time settings, such as the time format, date format, and country name.
Displays the system update information, such as the update number, installation date.
The following columns display the value for each of the preceding attributes:
Displays the scanned inventory item such as total memory and speed.
Shows the value of the items.
Shows the last modified value.
Shows the date when the item was last modified.
Note: You can show or hide these columns.
