You can change the value assigned to an attribute of an inventory item and update the database with the new value.
To change the value of an attribute
The Change Attribute Value dialog appears.
Lists all the attributes for the selected inventory item. Select the attribute for which you want to change the value.
Lists the values you can assign for the attribute. Enter the value you want to assign.
Locks the value for the selected attribute. This means that any value reported by the agent will be ignored. Select this option, if you do not want the agent to overwrite the current value.
Displays the date and time when the value was last collected by the agent.
Displays the previous value assigned to the attribute.
Creates a script job to change the value in the computer asset. Select this check box only for the template inventories.
Note: After closing this dialog, press F5 to see the changes.
