The System Devices pane displays the information about the adapters and controllers installed on the computer asset.
Note: The inventory information available in this pane depends on whether asset management is installed.
This pane contains the following columns:
Displays attributes of detected network adapters.
Displays information about detected IDE controllers.
Displays information about detected USB controllers.
Displays information about detected video adapters.
Displays attributes of detected floppy controllers.
The following columns display the value for each of the preceding attributes:
Displays the scanned inventory item such as total memory and speed.
Shows the value of the items.
Shows the last modified value.
Shows the date when the item was last modified.
Note: You can show or hide these columns.
