The Inventory pane displays the hardware inventory information collected from the selected asset. This helps you understand what resources you have and how they are allocated. The inventory information available in this pane depends on the detection modules configured in the hardware inventory collect task of the asset.
This pane displays both basic and advanced inventory information. Basic inventory information is collected by a lightweight agent that is installed on all the assets in the DSM domain. Advanced inventory information is collected by the asset management agent that is explicitly installed on the assets. Hence, the information available in each of the following categories depends on whether asset management is installed:
Note: Regardless of the language CA ITCM is running on, the inventory information will always be displayed in the English language.
Note: On UNIX platforms, the inventory information that can be retrieved depends on parameters such as the platform and the operating system version.
