The System pane displays information about the computer asset's CPU.
Note: The inventory information available in this pane depends on whether asset management is installed.
This pane contains the following columns:
Displays information about the processors such as model, speed, and vendor.
Note: The value of the processor attribute Serial Number is displayed only for the older versions of x86 systems such as Pentium III or earlier. For later versions, it will display the value as "N/A."
Displays the internal and external designators and the connector types for all the IO ports in the computer.
Displays the mother board information such as serial number, number of free memory banks, number of used CPU sockets, ROM size, and so on.
Displays the RAM information such as type, size, location, and so on.
Displays the BIOS information such as vendor, BIOS version, ROM size, and so on.
Displays the information about the slots in the system such as bus type, current usage, speed, and so on.
The following columns display the value for each of the preceding attributes:
Displays the scanned inventory item such as total memory and speed.
Shows the value of the items.
Shows the last modified value.
Shows the date when the item was last modified.
Note: You can show or hide these columns.
