The Network pane displays the information about the network configuration on the computer asset.
Note: The inventory information available in this pane depends on whether asset management is installed.
This pane contains the following columns:
Displays information about the TCP/IP configuration for IPv4.
Displays information about the DNS configuration for IPv4.
Displays information about the WINS configuration.
Displays all the IPv6 information such as IPv6 addresses, Gateway address, Gateway name, and so on under the DNS, IPv6 Addresses, and Gateways subnodes. These subnodes are included under the TCP/IPv6 node.
The IPv6 address format is different from the IPv4 address format. Each IPv6 address contains eight blocks of four upper-case hexadecimal digits separated by a colon (':'). No leading zeros are omitted and no zero blocks are removed. For example, 0123:4567:89AB:CDEF:0000:0123:4567:89AB is a valid IPv6 address format.
Note: The IPv6 inventory does not include any information about gateways on Windows XP and Windows 2003 Server. It provides gateways information only on Windows Vista and later versions of Windows.
The following columns display the value for each of the preceding attributes:
Displays the scanned inventory item such as total memory and speed.
Shows the value of the items.
Shows the last modified value.
Shows the date when the item was last modified.
Note: You can show or hide these columns.
