The Session Recording option toggles between starting and stopping a recording session. If you select Start, the Save As dialog appears, letting you choose where to store the recorded session. You may rename the default file name as long as the extension is "urc."
If the Record Remote Control Session option is enabled on the Viewer Properties, Record tab before establishing a session, the recording starts as soon as the session is established, giving you the option to stop the recording during the session in progress or end recording when you disconnect.
The following table summarizes the functionality of the Start and Stop menu commands and toolbar buttons:
Menu Option |
Toolbar Button |
Function |
Start |
Starts the recording of a session. The standard Save As dialog appears, letting you choose the location for storing this recorded session. When recording is started, this button remains depressed. |
Stop |
Stops the recording of a session. Becomes active only after you have started a recorded session. |
