Previous Topic: Specifying Text for Acknowledged EventsNext Topic: Setting a Limit on the Number of Events Received
Specifying Text for Cleared Events
You can specify text to be used when an event is cleared. To do this:
  1. Pull down the Options menu and choose the General ... menu item.
  2. The General Settings dialog box is displayed (see the previous figure).
  3. Deselect Use default Clear string.
  4. Type the text for cleared events in the Clear String field.
  5. Click OK.
  6. Pull down the Options menu and choose Save Options to save your settings.
