Using the Eventlist Interface › Customizing Eventlist › Change the Way Eventlist Works › Setting a Limit on the Number of Events Received
To set a limit on the number of events that are to be received by Eventlist:
- Pull down the Options menu and choose the General ... menu item.
- The General Settings dialog box is displayed (see the previous figure).
- Move the slider on the Max. Event Count bar until the desired number is indicated (1000 maximum).
- Click OK.
- Pull down the Options menu and choose Save Options to save your settings.
Copyright © 2010 CA.
