There are various changes you can make to the way Eventlist works. You can:
You can restore the default options by choosing Restore Default Options from the Options menu.
All of these tasks, except for adding actions to the command menus, are available from the General Settings dialog box, which is shown in the following figure. For instructions on adding actions to command menus see the section Add User-defined Actions to Event Command Menus.
Copyright © 2010 CA.
