Using the Eventlist Interface › Customizing Eventlist › Change the Way Eventlist Works › Specifying Text for Acknowledged Events
You can specify text to be used when an event is acknowledged. To do this:
- Pull down the Options menu and choose the General ... menu item.
- The General Settings dialog box is displayed (see the previous figure).
- Deselect Use default Acknowledge string.
- Type the text for acknowledged events in the Acknowledge String field.
- Click OK.
- Pull down the Options menu and choose Save Options to save your settings.
Copyright © 2010 CA.
