Using the Eventlist Interface › Starting Eventlist › Starting Eventlist from the C3 Interface
To start Eventlist from the C3 interface, pull down the Commands menu and choose the Restart Eventlist menu item. If you want the Eventlist window to appear automatically every time you invoke the C3 interface, you need to set up this option on your C3 interface.
To start the eventlist from the C3 Interface
- Pull down the Options menu and choose the General... menu item.
- This displays the General Settings dialog box.
- Click the Display Eventlist Window at startup checkbox.
- Click OK.
- Pull down the Options menu and choose Save Options to save your settings.
Copyright © 2010 CA.
