To start Eventlist from the command line interface:
Enter:
$ CONSOLE EVENTLIST
Available options are /NODE=, /SERVER=, /SCREEN= and /TRANSPORT=. For an explanation of them, see the following table.
Value |
Description |
/NODE=display-name |
The DECwindows Motif display you wish the window to appear on. |
/SERVER=number |
The number of the server on the HOST display, normally 0. |
/SCREEN= number |
The screen on which the window should appear. For single head workstations this is 0 and for dual head workstations it may 0 or 1. |
/TRANSPORT= {LAT | TCPIP | DECNET} |
The DECwindows Motif transport which your X-Windows client and server support. This routine supported TCP/IP, DECnet and LAT transports. |
Copyright © 2010 CA.
