To delete an event, choose the Edit Event Menu, Delete submenu. select the Event to delete, then click OK.
If you want to delete more than one event, then click Apply instead of OK. The Select Event dialog box is not closed, and you can now select another event to delete.
Copyright © 2010 CA.
