Previous Topic: Add EventsNext Topic: Modifying Events
Modifying and Deleting Events
Before you can modify or delete entries in the configuration database, you must have the Edit Configuration data privilege set in your user entry.
Note: We recommend that you do not remove the predefined Console Manager events (prefixed with CMGR) from the database. However, you may redefine the priorities of these events if you wish. Any changes you make to these event definitions may not be preserved when your Console Manager installation is upgraded with new releases.
