Previous Topic: Modifying and Deleting EventsNext Topic: Deleting Events
Modifying Events
To modify an event, choose the Edit Event Menu, Show/Modify submenu and then complete the Event dialog box shown in the figure in the section, Adding Events, earlier in this chapter.
If you want to modify more than one event, then click Apply instead of OK. This displays the Events dialog box, but does not close the Select Event dialog box. When you have changed the event, you can now select another event from the Select Event dialog box.
