When an automatic archive is activated, the value corresponding to the number of hours to archive is used to determine the amount of log data that will be moved from the active log file to the archive area specified in the archive directory field.
To set the time limit on the files to be archived and to set the directory where they will be archived, enter:
CM Edit> set archive Number of hours to archive (12): 24 Archive directory (CONSOLE$ARCHIVE): CONSOLE$STORE:
To keep the default values, press Enter. To set your own values, enter the new values you require. In the previous example, the default number of hours to archive data is being changed to 24 and the default archive directory to CONSOLE$STORE.
Copyright © 2010 CA.
