Previous Topic: Granting PrivilegesNext Topic: Setting Timeout
Setting Console Manager Characteristics
The following table shows the Console Manager characteristics and their default values in your configuration database when Console Manager is installed.
Characteristic
Description
Default Value
Timeout
The period in seconds that ENS, if enabled, waits for an action before declaring it inoperative.
60
Failover
The secondary host's polling frequency of the primary host and the number of seconds after which poll requests time out if they do not receive a response.
There are two parameters:
Failover Keepalive Timer (seconds)
Failover Polling Timer (seconds)
120
60
File space
The disk space thresholds at which a warning message is issued and an automatic archive is initiated, and the frequency at which the space checks are made. The thresholds indicate the amount of disk space used.
There are three parameters:
Filespace Warning Threshold (%)
75.0
Filespace Critical Threshold (%)
90.0
Filespace Check Timer (seconds)
600
Archiving
The period to archive, and the location of the archive files.
The two parameters are:
Number of hours to archive
12
Archive directory:
CONSOLE$
ARCHIVE
Note: The default values for Console Manager characteristics will be correct for most environments.
These defaults should be correct for your environment when you set up Console Manager for the first time. You may change them at any time to suit your requirements.
Use one of the set commands shown in the table in the section Configuration Editor Commands, earlier in this chapter, appropriate to the characteristics you want to change.
