Previous Topic: Setting FailoverNext Topic: Setting Archiving
Setting File Space Checking and Thresholds
The file space checking attributes determine the frequency at which each system's logging area is checked to see if it has exceeded the defined warning and critical space used thresholds. These thresholds are entered as a percentage of total available logging space. If the warning threshold is exceeded, an event is generated. If the critical threshold is exceeded, an event is generated and an archive process is activated.
To set filespace, enter:
CM Edit> set filespace
To keep the default value, press Enter. To set your own values, enter the number you require.
You can set the interval at which the file space is checked. In this example the number of seconds is set to 25.
Check disk capacity interval (600): 25
You can set the warning and critical thresholds:
Warning [1-99] (80): 75
Critical [1-99] (95): 90
In this example, the default warning value is being changed to 75 and the default critical value to 90.
