Use the modify command to change entities in the configuration database. For example, to change the user smithj entry in the database, enter:
CM Edit> modify user smithj
You can also change the values of actions, events, filters and scan profiles. This is discussed in the Chapter Setting Up the ENS Components.
To clear a field in the configuration database, enter only the \ character. If the field you are clearing is a required field, you are prompted for a value, with the current value listed as the default response.
Copyright © 2010 CA.
