Use the Modify Settings dialog to modify the policy settings for table structures, such as DTS share definitions.
Note: The Data Transport Service (DTS) is not available for some CA component plug-ins and applications.
To modify a policy
Note: Before you can modify a policy, you must unseal it.
If the policy has a table structure, the Modify Settings dialog appears and displays the policy name, description, and the rows and values currently defined to the configuration policy.
Alternatively, double-click a table entry to change its value.
Your changes to the table structure are saved.
