Previous Topic: Contact CA TechnologiesNext Topic: Domain and Enterprise Concept
The DSM Explorer
The DSM Explorer is the unified administrative console that provides a combined interface to view, interact, and control the features of CA Client Automation based applications and component plug-ins. The purpose of the tree structure in the left pane of the DSM Explorer window is to display your organization's assets and asset tracking features.
Your assets are grouped logically in system-generated feature-specific groups under the Computer and Users folder. You can also aggregate and create more groups to arrange the assets in your organization to suit your specific requirements.
The DSM Explorer tree is dynamic, based on the component plug-ins or applications installed. The DSM Explorer displays the following asset, configuration, and management features:
Software
Enables you to track, maintain, and catalogue software.
Note: Available categories and options may vary depending on the products and components installed.
Jobs
Enables you to automate execution of specific software or asset related actions.
Queries
Enables you to generate reports and create the criteria to group assets.
Policies
Enables you to define and activate policies.
Remote Control
Enables you to track and log remote control sessions.
Control Panel
Enables you to configure and manage the DSM infrastructure.
The DSM Explorer displays information from the MDB (a database with a unified structure for the storage of management data from multiple CA products) and schedule actions for a computer, a user account, a user profile, a group of computers, a group of user profiles or a group of user accounts.
