Use the Setting Properties dialog to modify configuration policies to suit your specific requirements and environment. Settings that are displayed in gray have not been set. Unmanaged settings are indicated by the crossed-out table icon with a section reference mark.
Note: Before you can modify a policy, you must unseal it.
For example, to change the value of the default TCP port
The TCP settings, their values, and their descriptions are shown in the TCP pane.
Alternatively, click Setting Properties in the Tasks portlet or double-click Port.
The Setting Properties dialog opens.
The new value is immediately shown in the list of settings and in the Details section.
Note: You can discard any changes you have made during an editing session by right-clicking the policy and clicking Discard Changes in the context menu that appears.
