The status of a configuration policy setting can be set to Centrally Managed (managed) or Locally Managed (unmanaged). The chosen setting allows administrative control over configuration policy.
Controls the behavior of plug-in components. Managers push a Centrally Managed setting onto a remote computer.
This setting is indicated by a table icon with a section reference mark.
Allows remote users to be able to control this setting. A Locally Managed setting is one that is configurable on the remote computer.
This setting is indicated by the crossed-out table icon with a section reference mark.
